weird symbol showing in attribute value
gcsjlewis
gcsjlewis
Recently i started having a couple of issues with my panel blocks.  I noticed it when certain blocks were not showing up in my bom.  While investigating i noticed a handful of attributes showing a value as such
MFG   \w0.7000;AB
CAT   \w0.7000;1769-OW8
ETC.
I noticed that the "\w0.7000" is the width factor.  For some reason i cannot figure out how to fix my block.  Other than creating a new one.
If i try to modify it through the quick properties or regular properties tab i can not click on it to edit.
Any ideas??
rhesusminus
Seems like your attributes are set to be multi line.
Try to set this to No:
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
gcsjlewis
It is not allowing me to change it. I can't click on it or anything. I can click on the other misc. items like invisible, backward etc.. But not multiple lines.
rhesusminus
I guess you'll have to edit the symbols with the symbol builder, and then run the block update function for you blocks.
Trond Hasse Lie
Ctrl Alt El
