How to get Signal coordinates via "API"?
rhesusminus
Mentor Mentor
rhesusminus
I need to to the the coordinates for the connection points (X??TERM?? attributes) for the signals I have spread around my project.
Can't find anything in the API documentation, and looking in the project scratch database, I only find connection point data for schematic components. Not for signals, not even for terminals.
Is there any way to find this information? Without actually opening each drawing with a signal in it (I can find what drawings they are in in the SIG-table of the project scratch database) and "scan" them?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
PatMurnen_Adsk
Trond Hasse Lie,
there are no published APIs that would do this. And you are right, the information is not in the project database. I think there is a way this can be done using some of the internal calls AutoCAD Electrical uses to get information from a drawing that may not be open or active. This will probably take some back and forth and might be better done through email. If you want to give this a try let me know at pat.murnen@autodesk.com. Would be a nice little challenge and maybe we can make it generic enough to get this information for other components.
Pat
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Autodesk, Inc.
