AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
WD_TB title block attribute alignment issues
22 REPLIES 22
Message 1 of 23
2055 Views, 22 Replies
Looking for help with a title block issue.  Currently the title block will not insert all the lines in there correct place as was setup.  If possible, how can this be realigned?  The fields don't seem to fix the problem no matter what they are changed to.  See attached items for reference.
22 REPLIES 22
Message 21 of 23
rhesusminus
Just good scripting practise.
Commands that start with a hyphen will be run on the command line, without any dialogs popping up.
Type -INSERT and INSERT on the command line to see the difference. One CAN turn off dialogs for commands with the CMDDIA variable, but then you need to remember to turn it on again, because sometimes the scripts crash 😄
Just like the FILEDIA variable that AcadE forgets to set back to 1 every now and then.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 22 of 23
in reply to: rhesusminus
I Have just noticed that the preview for the tahoma font does not appear, could this indicate the issue?
Thanks.
Message 23 of 23
rhesusminus
I'm not sure if that's it. Tahoma shows here, for what it's worth 😄
If you go to Control Panel -> Fonts
Locate Tahoma, right-click -> Preiew
What do the windows that open look like?
Trond Hasse Lie
Ctrl Alt El
