- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a large drawing with many different symbols in use, that is currently being worked on. However all the symbols have the tags for install, location and tagname in the same size font in a similar position.
The client would like the tagname clearer larger and the install and location codes smaller. Since I only work for this client it is important to find a way to do it.
I think there is a library tool that can change fonts and height in library symbols on a library basis, but I would like to know if there is a vba way of not only this but shifting the co-ordinates of tags by hardcoded values based on the tagname with the symbol. The catch is this is within the symbol definition- these are not isolated tag attributes on the drawing.
Also for me I would prefer to alter only the symbols in use on the drawing. If I sent a routine to alter the entrie library it would take an enormous time to run.
However the key unknows in VBAn for me are opening, searching, altering, saving, updating the symbol definitions.
I can of course edit each symbol in AESYMBUILDER and AESWAPBLOCK them back. I just wondered if anyone in the Community had met this problem for large numbers of symbols and no time available and how they solved it.
Thanks for your advice and regards to all of you,
Roger.
