Using LISP c:ace_projwide_script to run a project wide script
Damian_Lee3WBMU
Damian_Lee3WBMU
I have tried to use the flowing lisp file to run a script for each drawing in the project:
(defun c:ALLDWGS ()
(c:ace_projwide_scipt nil ALL_LINKS)
The script file "ALL_LINKS" is already loaded and runs if I call it from command line. The script for that is as follows:
(defun c:ALL_LINKS ()
(COMMAND "DATALINKUPDATE" "U" "K")
(COMMAND "ZOOM" "E")
Could these commands be incorporated into the "c:ace_projwide_scipt" somehow?
Any help would be greatly appreciated as I am new to this.
Regards
Damian
Thomas.CoxTFXY8
This is already built in AutoCAD Electrical, see "run script file" below
Damian_Lee3WBMU
Thank you for the reply, but I want to use LISP so I can add it to a custom button on the menu.
james.mcmillanNYR6A
The script file you are trying to run, all_links, is a lisp file, not a script. You could write this lisp as a script, or write a script file to run this lisp
james_moore
Save your code as a script file, instead of a LISP.
If you structure it correctly, it will process as if you were entering the LISP manually from the command line:
(defun c:ALL_LINKS () (COMMAND "DATALINKUPDATE" "U" "K")(COMMAND "ZOOM" "E"))
(c:ALL_LINKS)
... this saved as filename.scr should work just fine, and be usable from the Run Script option in the Project-Wide Utilities to apply to the drawings you select from your project.
