- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am posting this after a recent experience where the panel builder used red wire for 24VDC signal wires. The signal originates from a VFD's control board I/O pin "VO24", and I foolishly assumed this was enough information, and of course all wires on my drawing are black. So in summary, I did not specify the signal voltage on my drawing and expected the panel builder to just know what color wires to use.
I think the remedy to this is using layers where I can have 24VDC signal wires on one layer, and 120VAC wires on another layer, with each layer being color-coded. So I was going to create another layer (say WIRES_24V) and set the color to blue. But it is my understanding that wires can only be on the WIRES layer, otherwise the wire will not cut when components are placed on it. Not sure if there is a way to subdivide a layer where all the wires are still on WIRES layer but different colors can be used for wires carrying different voltages. Please advise.
All wires in Drawing1 are 24VDC.
