Using destination arrows
snorcisa7FS8E
Message 1 of 11
snorcisa7FS8E
Hello, I'm using a single out arrow and multiple in arrows on a sheet. The project properties for cross-referencing are set to %S%N. However when the cross referencing displays it shows as the sheet then the shortened line number
(IE instead of 1005, it displays as 05, so sheet 10 line 1005 shows as 10-05).
How can I fix this?
Also, I seem to remember back in older versions of AE when the string of cross references was too long and you wanted to "wrap" it there was a way. Is this still possible?
Accepted solutions (3)
Replies (10)
Message 2 of 11
trabuck7
In the project properties under Cross-References you can set up the format to be '%S%N' . Be sure to apply the project defaults to any drawings as well since they can be different.
There is also a way to wrap xrefs like you describe.
Tyler Rabuck
Electrical Engineering Technician
Message 3 of 11
snorcisa7FS8E
Thank you!
That did the trick.
Message 4 of 11
trabuck7
You're welcome! That's a feature I rarely use and had to think where that was even located.
Tyler Rabuck
Message 5 of 11
ramesh.kambang
To wrap the text i.e. to change the Cross - Reference Line to multiple text, add vertical bar (|) in the project / drawing properties as shown below:
This way you don't need to convert xrefs manually every time. ACADE automatically converts xrefs to multiple text lines when you perform project or drawing-wide xref update. Very cool feature.
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
Message 6 of 11
snorcisa7FS8E
But can you control WHERE the break happens doing this?
Message 7 of 11
ramesh.kambang
This setting converts the string of xrefs (two or more xrefs separated by comma by default) into the multiple mtext lines exactly the same way as using command AEXREF2TEXT or icon as @ trabuck7 posted. If you can control the break in the other method, you should be able to do in this method as well.
Ramesh Kambang
Message 8 of 11
snorcisa7FS8E
I will definately try this!
Message 9 of 11
ramesh.kambang
See the extract from acade help for more details
Ramesh Kambang
Message 10 of 11
snorcisa7FS8E
ramesh, unfortuneately this wouldn't be the best answer for me because it seems to affect all cross references, not
just the destination or source arrow references. It seems to have affected my cross references for relay children as well. Good idea tho.
Message 11 of 11
ramesh.kambang
This does project-wide or drawing-wide (all xrefs) so that you don't need to do it manually. If you don't want this to happen on a particular drawing, you need to replace vertical bar with comma.
Ramesh Kambang
