User1-20 from Wire Layer type are not showing in the From/To report.
testsubject
Advisor Advisor
Message 1 of 10
testsubject
I am trying something I have not used before and it is not working as expected.
I added a value to USER4 in the Wire type table and then in the report I added User4_1 and USER4_2 to the report but bot are blank. Did this get removed sometime in the past?
I did run AEREBUILDDB before running the From/To report.
Am I missing something??
Bob Hanrahan
Ace User since 1998
Autodesk Expert Elite Alumni
If this answered your question, please click on "Accept Solution"
Replies (9)
Message 2 of 10
ramesh.kambang
Did you use From / To or Cable From / To? I used just From / To, see below
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
Message 3 of 10
testsubject
Okay, that is weird. I do not see that if I do the same thing you did.
I am using ACE 2022
Bob Hanrahan
Ace User since 1998
Message 4 of 10
testsubject
I forgot to mention that I am using "Wire From/To" not "Cable From/To."
Bob Hanrahan
Ace User since 1998
Message 5 of 10
rhesusminus
Just tried in 2022 here.. Works as expected.
Will it work in the demo projects that come with AcadE?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 6 of 10
testsubject
Trond,
It is really strange. I opened up the NFPADemo and added "TEMP" to the User4 for the BLK_14AWG.
This is how the report displayed:
Nothing in User4_1 or User4_2.
When running the report, I just click on "Wire From/To" in the Schematics Report, select current page, and pick the defaults for the report. I then click okay and then select "all" on both sides of the dialog box and click OK again.. The above is the result.
Bob Hanrahan
Ace User since 1998
Message 7 of 10
Icemanau
Have you saved the report format?
I tried this and got your results initially, but then I saved the report format before re-running the report and they showed up.
Regards Brad
Brad Coleman, Electrical Draftsman
Message 8 of 10
ramesh.kambang
Ramesh Kambang
Message 9 of 10
testsubject
Ramesh,
In my image above, I show both User4_1 and User4_2 in the report. Yes they were selected.
Bob Hanrahan
Ace User since 1998
Message 10 of 10
ramesh.kambang
Sorry, I didn't see them you had those fields. This feature works on both 2021 and 2022, very strange why doesn't work on yours. Did you try this by creating a new project (from demo)?
Ramesh Kambang
