Unplottable Non Existing Sheet
diego.cardenasZANG3
Observer Observer
diego.cardenasZANG3
Observer
Observer
Hi, I'm getting this error while trying to plot the project, there's no page 27 tho, does anyone know how to solve this?
Thanks!
Thomasbatson
I have seen that when I deleted a drawing in windows but left it in my project manager.  Can that be it on yours?
jseefdrumr
Which command are you using to plot?
If you're using the ACADE publish command, it shouldn't give this error at all because it won't try to plot a drawing that isn't in the project. Unless, of course, it's in the project but deleted elsewhere as noted by @Thomasbatson.
If you're using the ACAD publish command, simply don't include drawing 27 in the list.
If you're plotting from a .dsd file, it needs to be rebuilt in order to remove drawing 27 from the plot list.
Jim Seefeldt
Electrical Engineering Technician
diego.cardenasZANG3
Observer
Observer
I used AEPUBLISH, yeah "left it inmy project manager", that was it, however I started getting another error as soon as I fixed that one, see image below, after trying differnt things restarting AutoCAD made the trick. Thank you both!
