AutoCAD Electrical Forum
UNICODE GROUND SYMBOL
6 REPLIES 6
7329 Views, 6 Replies
I was wondering why ACADE does not include the Unicode symbol for earth ground (u+23DA) in the special characters group.  Is there any way to add this?
6 REPLIES 6
stefan.stamate
Not sure why would you need a symbol... ACE 2013 has a ground symbol under Inser Schematic Components/Miscellaneous.
in reply to: stefan.stamate
I use the ground symbol in schematics all the time, but sometimes I need a ground symbol in text as well and that is not available.
shuhn
It would be nice if ACE supported Unicode symbols all around.  I want to put the symbol in my attributes for a terminal on a symbol, as this is how the MFG labels the terminal.  I was able to copy the Unicode degree sign into an attribute successfully, but the GND symbol will not work.
rhesusminus
in reply to: shuhn
This all depends on the font you've chosen to use for your text style. The old SHX-fonts do not have the complete character set. Try using a truetype font instead, and maybe you'll have more luck.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
shuhn
in reply to: rhesusminus
Yes, it answered my question, but I don't see "Accept as Solution" anywhere.
jseefdrumr
in reply to: shuhn
you only see 'accept as solution' if you're the OP (Original Poster).
Also, keep in mind that not all ttf fonts include every unicode symbol. Here we use unicode in text to represent phase symbols, ohms, and delta. It took a while for me to find a font that had all three of these, AND conformed to our other needs (sans serif, no confusion between 1 & I, O & 0, 5 & S, etc). We ended up using Gulim.
Jim
Jim Seefeldt
Electrical Engineering Technician
