Unhandled Exception c0000005 (Access Violation Reading 0x0c38)....
brent_e_barbour
brent_e_barbour
I'm linking an emx file between AutoCAD Electrical and Inventor 2018.  I assembled all my connectors in Inventor then generated an emx file so I can insert the connectors into an AutoCAD schematic drawing.  The emx file seems to link okay and all my connectors are listed in the "Location View" tab.  However, when I right click on a connector from the list and select "Insert Connector (From List)", I get the error "Unhandled Exception c0000005 (Access Violation Reading 0x0c38) at address a17d7dd9h."  Any ideas?
     Brent
brent_e_barbour
brent_e_barbour
Never mind.  I figured it out.  Apparently you can't insert those connectors in AutoCAD if that session of Inventor is open.
