Unable to edit SQL database in catalog browser
rhesusminus
Mentor Mentor
Message 1 of 11
rhesusminus
@PatMurnen_Adsk
I've found that if I add a a manufacturer with a forward slash in the name, the Edit-button in the catalog browser stops working.
Screencast:
I found the problem, and that is that this create a PINLIST-table with a forward slash in it. If I rename this table, everything works fine again:
So, please consider this a bug report, and I posted it here in case someone else should stumble upon this.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Replies (10)
Message 2 of 11
rhesusminus
Solved
Trond Hasse Lie
Ctrl Alt El
Message 3 of 11
PatMurnen_Adsk
Trond,
I wasn't sure of the exact problem from your video and I wasn't able to reproduce any problem at my end. From the video it looks like each time you click the edit icon it goes into the edit mode. I am sure I am just missing the obvious.
Pat
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Autodesk, Inc.
Message 4 of 11
rhesusminus
Look at the pencil button. It doesn’t change to «accept/cancel»…
The grid turns yellow as in edit mode, but there is no way to save your changes.
Sent from my Windows 10 phone
Trond Hasse Lie
Ctrl Alt El
Message 5 of 11
PatMurnen_Adsk
Ahh, yes I was missing the obvious. I will make sure this is logged if it isn't already. Thanks for reporting it and putting it here in case anyone else runs into this.
Pat
Pat Murnen
Autodesk, Inc.
Message 6 of 11
rhesusminus
While we're at it @PatMurnen_Adsk ....
The content migration utility does NOT migrate the column names from the access database into the SQL-database.
If I rename the USER1-3 columns in table AM, they are still called USER1-3 in the SQL database after migration.
Trond Hasse Lie
Ctrl Alt El
Message 7 of 11
PatMurnen_Adsk
Trond, It may be intended as I have been seeing some things where the AutoCAD Electrical team is strongly recommending that people not rename any of the columns. But, I will let you know what I find out.
Pat
Pat Murnen
Autodesk, Inc.
Message 8 of 11
PatMurnen_Adsk
Trond, I did hear back from the team that this is a known issue. So it is logged. Sorry it took me so long to get back on this. I was out of the office for a little while.
Pat
Pat Murnen
Autodesk, Inc.
Message 9 of 11
rhesusminus
Ok, thanks.
What about renaming columns?
This article (dated Feb. 22 2016) says : Prohibitions, Column Labels. Do not change the column labels.
While this article (dated May 2 2016) says : Edit Column Labels, Edit the field names as needed.
So....
Trond Hasse Lie
Ctrl Alt El
Message 10 of 11
PatMurnen_Adsk
Trond,
Over the past few releases the catalog database structure is getting more restrictive for many reasons.
  • It is used to insert 2D symbols in AutoCAD Electrical
  • It is used to insert 3D symbols in Inventor
  • It is used in many reports
  • There is an editor for it
  • It is used when you do a quick bom
  • It is migrated and in migration there are a number of options, MDB, SQL, overwrite, merge, etc.
  • and more things I am not thinking of right now
Anyway, my point is that there is a lot of code that touches accessing for read\write of the catalog database. It is probably safe to rename the user columns and the columns that are named differently from table to table. But as we can see there is a problem in the migration of these. Some columns cannot be renamed, such as CATALOG, or many functions fail. So its a little bit of a gray area. So the best practice (and safest) is not to rename any of the columns.
I believe that the second article you mentioned, To Work With Catalog Database Tables, should be updated to add a note in the Edit Column Labels to list the ones that should never be changed and a caution about this. I will log this.
Pat
Pat Murnen
Autodesk, Inc.
Message 11 of 11
No - (dashes) either.  That is a problem as well.
