Turn off mixed version of AEC objects popup
channel.j.sisneros
Observer Observer
channel.j.sisneros
Observer
Observer
Is there a way to permanently turn of the "mixed version of AEC objects participating in this operation" popup message?  I am currently running 2016 and the company makes us save down to 2013.  I have to paste in items from one drawing to say 100 other drawings and it pops up every time I hit CTRL V.  I want to just turn off the message.
rhesusminus
Have a look at this article:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
channel.j.sisneros
Observer
Observer
This doesn't help.  I am pasting an item from one drawing into thousands of other drawings.  For each drawing I get the popup every time and want to just disable it from coming up at all.  I don't have a lot of options at work on how to open or save drawings to a different file type or version.  They have created their own document control system that will only accept drawings as 2013 and I am running 2016 electrical.  Even if I did change the version as soon as I check the drawing back into their system it automatically changes it back to 2013 so if I have to make another change I am right back to were I started.
jseefdrumr
Did you try to install the object enabler?
Jim Seefeldt
Electrical Engineering Technician
