Hi all.
I'm working on adding probably more detail than necessary on a schematic representation for a sensor.
The problem I'm having is getting ACADE to show the second and third mfg's and part numbers for a component.
Attached is the drawing. The prox sensor doesn't want to show the second mfg and part number where as the pressure transmitter does. I essentially copied all the properties from the PT to the PX, but when I insert and populate the PT, it's still not showing.
Any thoughts on why one works and the other doesn't are appreciated.
Solved by rhesusminus. Go to Solution.
The problem seems to the naming of the extra MFG/CAT attributes
All extra attributes of that kind should have the numbering starting from 01
So, the first of the extra ones should be MFG01 and CAT01
Using the AEXDATA command, I can see that AcadE has saved your part numbers in the XDATA instead of the attributes. (To MFG01 and CAT01)
Thank you rhesusminus. So now my question is, how do I get it to save it as an attribute instead of as xdata?
I went into the block and edited it (bedit command) to be mfg01 and cat01. Doesn't appear when I exit the editor. Shouldn't it have been an attribute when the block was created? Or.... did I miss something during creation and it is behaving "properly" for what it is?
