AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Title Block project wide update
5 REPLIES 5
HyperOle
802 Views, 5 Replies
I'm having problems when running "project wide" update of the title block. When I do it puts in DWG description 1 both where it should be and also where I want dwg description 3 to be. In the command field it also says it updates my attribute from what I want to the same as in the attribute for DSC 1 (see attached picture).
When running "Active drawing only" it works as it should. Any ideas?
regards,
Ole
5 REPLIES 5
ramesh.kambang
in reply to: HyperOle
Have you tried by ticking the box "Activate each drawing to process", see marked in RED?
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
HyperOle
in reply to: ramesh.kambang
Tried, but it had no effect.
Have however recearced a bit more, and noticed that the WD_TB attribute had "TITLE#4" listed two times, where it was wrongly overwritten the last time.
Do not know why it did so only when processing the whole project and not by active drawing only, but now it works...
vladop
I had the same problem with all attributes containing # character.
It must be preceded with ` character.
"TITLE#4" works only in active drawing but "TITLE`#4" works project wide too.
AND THAT IS EXPLAINED IN WDT FILE:
;; Note: if the title block's target attribute tag name contains one
;; or more "wild card characters" (they are: # @ . * ? ~ [ ] - )
;; then the name MUST be preceeded by a grave accent character `
;; Example: `[REV] = LINE5 (where title blk attrib name is "[REV]")
Vladimir
ramesh.kambang
in reply to: vladop
Another tip is: if a long attribute, for example, "Customer, City" is used, it will update only when the drawing is active. Hence, this long attribute must be written as Customer_City to be able to update project-wide (without activating each drawing to process).
Ramesh Kambang
jseefdrumr
You can't create an attribute with a space in it, the spaces have nothing to do with the character limit in an attribute. And anyway, 'drawn by' and 'drawn_by' have the same number of characters.
That said, there's definitely a character limit for attributes. It's just that the inclusion of the underscore has no bearing on what happens if you activate each drawing to process or not. If the attribute is too long, it's too long.
Jim Seefeldt
Electrical Engineering Technician
