AutoCAD Electrical Forum
Terminals with different wire numbers
6 REPLIES 6
673 Views, 6 Replies
Morning all,
I'm having a bit of a fight with terminals and wire numbers.
I have the same terminal shown on two different drawings. Two wires which should be numbered the same are terminated into the same terminal. Yet AutoCAD numbers the wires differently.
I can manually fix the wire numbers, but this doesn't solve the root problem. Any pointers as to what might be wrong here?
6 REPLIES 6
rhesusminus
You can't just insert the same terminal twice...
Did you associate them like a "multilevel terminal", and jumper the "levels"?
As AcadE sees them right now, they're two separate terminals.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
Thanks for the reply. I'm relatively new to ACDE so this might be obvious to those who've been using it a while.
I'll try and describe what I'm trying to do - maybe I'm doing this the wrong way.
I have two subsystems in the same panel that share a +24VDC connection. I have each subsystem on separate drawings, thus the +24VDC terminal shows up twice. This isn't a multilevel terminal, it's a normal terminal with two wires connected to it.
If ACDE can't handle showing the same terminal twice then how should I be drawing this?
rhesusminus
Well.. There are several ways to do this.
The easiest would be to draw the terminal one place, connect a wire to it, and use source/destination arrows to send it to the other page.
For one customer, I created custom destination "arrows" that looks like a terminal. It looked quite well.
You also have the ability to associate terminals in AcadE. Mostly used for multi-level terminals, but you CAN use it for "internal/external" side of the terminal as well, instead of "top/bottom" level.
I guess there are other ways to do this as well...
Trond Hasse Lie
Ctrl Alt El
ramesh.kambang
 As  rhesusminus mentioned, there are several ways but it needs custom symbol rebuilding skills. If you are new to acade, I suggest to use source to destination arrow method till you learn more about terminal / multilevel / jumper or terminal links etc. This is the easiest and quickest way of doing job done.
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Thanks all for your replies.
I haven't fully resolved this, but will use source/destination arrows for now. I will mark as resolved.
ramesh.kambang
The main advantage of using Source / Destination method is you don't need to create an additional pictorial views or terminal charts for clarity, e.g. if you have multi-level or internally linked terminals you have to create a chart to show how the terminals are internally lined /jumpered or multi-level etc.
Ramesh Kambang
