Terminal Strip Issues
rickstarosto4361
rickstarosto4361
Terminal Strip, i am having some issues with terminals, i have deleted these terminals from the project, but when i open terminal strip editor  (see screen shot: odd number 9 thru 23) they are still present in the editor,  i tried to delete under spare (it did delete jumpers) and accessories flyout but it says "invalid grid selection". (see screen shot).
james.mcmillanNYR6A
Does it work if you unassociate / break apart first?
aykutas
Did you try to delete by right click>Accessories>delete?
If the terminal you're trying the delete is not the terminal from the project, it gives "invalid grid selection" error message. Try to delete other duplicate one in the terminal strip editor. It may be the deleted one in the project and should be deleted in the terminal strip editor.
A
obulesub
Hello @rickstarosto4361 ,
Did the information provided by @aykutas  help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
All the best,
Obulesu | Community Manager
obulesub
Just checking in—did the responses shared by aykutas  help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
