- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In ACADE 2015.
I have a schematic that has muliple instances of power and ground terminal blocks, each with a single terminal number repeated.
In the panel layout, the terminal strip editor does not allow me to combine the wire connections to the fewest possible terminal blocks.
I am also having difficulty making two wire connections into external connections on the same terminal block.
I cannot associate some terminals to terminals that clearly have a free spot available.
I know these issues exist with the TSE.
Does anyone have an alternative tool for showing terminal blocks and wire connections?
Or, Is there ways to set up schematic terminal blocks to trick the TSE, i.e. a seperate terminal block symbol for bus wiring.
