Benchmark data:
1. AutoCAD Electrical 2010.
2. Single level terminals with one wire per connection used
3. Terminal strip XT3 with 5 terminals
4. Please see picture with drawing and terminal strip editor attached.
Problems:
1. Terminal strip editor (TSE) doesn't show all wires connected to terminal. Please see picture attached.
2. TSE doesn't create extra terminal for wire #1. should be 2 pc and 4 connections
3. for wire #2 should be 3 terminals and 5 connections. But only 2 terminals and 3 connections exist.
4. For wire #2A should be 2 terminals and 3 connections. But only 1 terminal and 2 connection exist.
As I remember first time TSE has created correct quantity of terminals and connections, but after some changes I can not return it back.
Thank you
Solved by Icemanau. Go to Solution.
Brad Coleman, Electrical Draftsman
