Good afternoon,
I am working with three-layer terminal blocks and I was hoping to control some of the data visible with the attributes WIRENOL, L02WIRENOL, and L03WIRENOL.
My desired result is to only show a single wire number instead of dual wire numbers separated by a semicolon (for all three attributes).
I was able to manipulate some of the destinations in the Terminal Strip Editor (using the Switch Terminal Destinations button) to get some of them to show a single wire number however I cannot get all of the wires to behave how I want it to look. Please correct me if I am wrong, but the internal data should be to one side (say the left) and the external data to the other (say the right), is this correct?
To clarify my initial question:
In the attached photo the third terminal shows:
1311.1 1301.1;1301.1 1301.0;1301.0
My desired result:
1311.1 1301.1 1301.0
Is there an easier/better way to manipulate these values?
Solved by mgaudyK243P. Go to Solution.
I believe I found the solution to my issue before.
Under wire connection, there is a drop-down menu for "others"
By default, connection direction is "left"
What I needed was 3 level terminal with a direction to the "right"
After spacing each connection with 0.5" spacing . . . I get this:
I hope this info is useful for others. Kind Regards.
