A real quick question first off which will allow us to help you better...
What release of ACADE are you using?
Including this information in your questions will lead to quicker answers as each release of ACADE has some major differences from the prior releases.
To track down a problem or to answer a How-To question requires us to know which release we should be looking at and as much other information as possible (workflow which causes the problem as an example).
First of all, check that the wire actually has the 'L1' number associated with it. If the number is not associated with the wire, run the Drawing Audit (found under the reports tab) to make sure that any problems are fixed.
Next, check that the correct block has been called by the component menu.
The block name for a square terminal showing a terminal number with no wire number change is HT0001.
Hovering over the icon in the component menu should show that file name as well.
The block name for the terminal showing the wire number should be HT0W01.
For the block that changes the wire number, it should be HT1001.
If these are wrong, you will need to edit the Component menu to correct it.
Another problem that showed up in some of the older releases was that some of the terminal blocks did not have the correct attribute names on the wire connections.
It's hard to see the fine detail like the attribute names in your screen shot but all the X#TERM$$ numbers SHOULD have the same number on the end.
In other words, they should all be X#TERM01. If the block name is indeed correct (either HT0W01 or HT0001) then you may have a bad block.
This is easy to fix by opening the block as a dwg and changing the incorrect attribute names so they all match.
If it is the correct block, and the attribute names are also correct, double check your wires and make sure they are all connected properly and there are no spurious connections to another wire that uses the 104 label.
If all else fails, try deleting the three wires and re-inserting them while making sure to add the terminal before adding the Tee.
Regards Brad
Brad Coleman, Electrical Draftsman
