The report From/To should not have "hanging" wires (one end of the wire is not connected).
What symbol should I place on the ends of the wires L1, L2, L3, PE?
A parent component, a child component, or something else?
I usually just trim them off when I reach the end of my 3-phase stuff, see image. If for some reason you have to show the free end of the wire, then what I would do is still trim them off, but then go back and draw the free end of wire and put it on _MULTI-WIRE (or some other layer that doesn't show up in wire to/from reports...I don't use that report so I don't actually know whether or not MULTI-WIRE will appear in it.)
Hope this helps,
Jim
surprissed nobody answered your question
below is the IEC symbols for a wire end which is not terminated
thr one on the left is a wire with no special arrangements
the one on the right is a wire with the end folded back and insusalted
what i do is use the insulated symbol you can associate a part number to the end which is a dummy entry with the description of wire end insulated
or what i do is allocate a piece of heatshrink tube to the symbol
either way works for me
Those symbols ae fine for wires left flying in the actual panel.
The question is about the wires shown as part of a bus system and how they show up in a From/To Report which is a totally different situation...
Any solution apart from changing them to a layer that is not reported will still have the wires show in the report.
If you want to tie them off, you can create a wire end symbol which has just invisible attributes and a visible dot similar to the Inline Wire Number. Just remove all the wire no attributes, add a TAG1 attribute and all 4 wire connections centred on the visible dot. This will then work for all 4 connection directions.
You may have to play around with it to get it to work properly but shouldn't be to much trouble.
Regards Brad
Brad Coleman, Electrical Draftsman
Thank you all for your help!
If I understood correctly, there is no special symbol in the schematic library. I need to create it myself. Usually, I create a child component with the TAG1 attribute and a connection point. The attribute TAG1 is assigned а value L1, L2, L3, PE.
Maybe there is a better solution?
