I can't get the UM to show up in the BOM for sub components. Any ideas of what I am doing wrong?
Trond, thanks for replying. Unfortunately it does not seem to matter which one I run.
I'm not seeing anything in the UM field either. I haven't tried to use it in a very long time though. I guess somewhere along the way the updates caused a regression related to unit of measure.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
I got it...
of course I put in 20.5 for the count...and it only reports the integer value...
These values were on the panel footprints themselves... not the schematic.
oops, not a sub...
Yep, doesn't pull for multiple catalog entries.
maybe both have to be same units?
nope.
Not pulling multicatalog UM.
Xdata is there though:
I just wrote my own tool to measure stuff (or get length data and the units) and update the BOM myself.
Unconditionally that is just for first level assembly. I am wanting to be able to add units in the "multiple catalog" as well.
Looks like this version of ACADE won't do that.
Besides, the limitation of only being able to have nonrational numbers in the "count" area sort of limits it's usefulness...
The problem can be solved with code, that's what I wound up doing for our wireway, dinrail, and busbars.
The data is probably in the project/dwgs/blocks/attributes... it's just a matter of getting at it and putting it to work for you.
Thanks for reporting this issue to us! I can reproduce this issue in ACE2020 as well as ACE2014. We have added this issue into our issue system and will consider fixing it in the future release.
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
