Hi all,
Since i updated to Acade 2016, when i insert source signal arrow into my drawings, the first one i say no to the question: do you want to insert the destination arrow. And also check the do not ask again. Then the program takes a while to actually insert the source signal, and any subsequent insertion is taking from 5 to 30 seconds to complete.
You guys have a clue on what is happening. I've been struggling to find a solution as in my company, we use a lot of them.
Solved by rhesusminus. Go to Solution.
Thanks for trying to help me. The folder C:\users\public\documents\autodesk\acade 2016\libs\ is listed in the support file search path.
One thing I did is in our domain, we use redirected folder, which when I'm connected to the network, the project folder is getting very slow. So I've moved the project folder on to my C:/Autodesk project files that i've created. I did changed the project path in the support file search path.
Another update is i started my computer this morning and the source signal are creating blazing fast. It already happened that in the morning it works fine but later it getting very slow.
Here's my computer config:
HP EliteBook 8770w
Win7 Pro 64bit
Intel Core i7-3820QM 2.70GHz
32.0 GB ram
480GB SSD
NVIDIA Quadro K4000M Driver Version: 10.18.13.5442
I meant the library folder for your project:
How if you try to open one of the demo-projects that comes with AcadE 2016.... Do you have the same speed problems with those projects?
The only ones I have in the public folders are:
C:\users\public\documents\autodesk\acade 2016\support\en-us\
Should i add all the others like your example?
They do exist, I added them to the list.
Excuse me for the dumb question but i noticed that all the path in your example are forward slash (/).
Mine are all back slash... (\)
Is there any difference??
I will try as soon as it go slow again.
Thank you very much for you help. Very appreciated
Just for you guys to know.
Since i added all the folders that Rhesusminus suggested, it generate the source arrow as expected.
Thanks all for you're help!!
