Source/destination arrow edit & update incredibly slow
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a problem with source/destination arrow updating and editing that is extremely slow. The project I'm working on is a typical 100 page project with same terminals running from page 10 to 90 (voltage supply) that are linked with jumper bars. On each page source destination arrows are placed. The setup are same in each project, but in some, you have to add or remove pages and then update references accordingly
Let me give you an example, when I right click on a signal arrow and want to edit, with command trace on it starts chewing for a long time spitting out;
IN:wd_wnuma_get_wire_netlst_mdb
OUT:wd_wnuma_get_wire_netlst_mdb
IN/OUT:wd_wnuma_get_wire_num=nil
IN/OUT:wd_1_get_hdl_ptr_xdata_notactive=nil
This goes on forever until the edit window pops up. If I change anything and clicks "OK" it then again starts chewing away. This is seriously affecting workflow and driving me crazy. Is there any way to recreate this netlist or update it?
Thanks.
