Show/Edit Miscellaneous
Please any Help on this Issue, First I opened a  WD_addattar_comp and added some attributes and save it, than on my panel layout drawings I use Schematic List command to bring the footprints into the drawing, once I insert the footprint component and go click on Show/Edit Miscellaneous    AutoCAD freezes? I could not find out why it is doing so.
rhesusminus
If you press ESC, will AutoCAD continue?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
No, I had to go to task management and end the task.
rhesusminus
I just added a new attribute to my WD_PTAG_ADDATTR_COMP, and inserted a new footprint. Worked like a charm.
Could you post your WD_PTAG_ADDATTR.COMP.dwg here?
Trond Hasse Lie
Ctrl Alt El
 Did you use Icon Menu or Schematic List to insert your footprint? because I tried it with Panel Icon Menu and it works fine, but when I use Schematic list it freezes AutoCAD. Thank you
rhesusminus
Tried with your file, and I use the Schematic List. Still no problem.
Is it possible that the WD_PTAG_ADDATTR_COMP block already exists in your drawing?
If you try to purge, and have a look at stiff that can/cannot be purged.. Can you see that block there?
Trond Hasse Lie
Ctrl Alt El
Ok great, because I thought I had it work for some time but was not sure. I did purge my drawing but still the same problem. I did also try it with some team members, since we are sharing the same databases and libraries, they do have the same problem.
