Hello all. Just a bit of information first. I work for a small electrical engineering company and we do a whole range of work. We have some work that involves pump stations, filtration plants, or chlorination processes. For those projects we create the P&ID, panel layout, wiring schematic, and loop diagrams. We generally do not create reports or BoMs for these drawings as far as I know. I am currently the person responsible for trying to learn if ACADE is going to work for our workflow and if it is then implementing it. We currently use ACAD MEP for our work. We don't use really any of the AEC part of MEP however. We do use the project manager though.
Usually the way that we do the work for these projects it by getting either a P&ID narrative or a P&ID schematic done by another 3rd party. We usually then take that P&ID create our version of it and then create a wiring schematic from it. And then from that wiring schematic we create our panel layouts and terminal strips. And then from there we will create our loop diagrams. However from the testing that I've done with electrical, I'm sure I've just touched the surface on what it can actually do, I've run into several issues however that have been fairly major stopping points for what we want to the software to do. I am currently doing this testing on ACADE 2020.
I guess what I am looking for is an opinion on how well electrical would work for the workflow described at the top. And if they best way to work around some of the issues that I have mentioned is to create custom blocks that link together slightly differently or something along those lines. Or if ACADE just doesn't work for the described workflow or not.
Sorry about the mountain of text in a single post.
Ethan
p.s. OK it appears that posting something too long makes it get flagged as spam and then deletes it. I'll be splitting this into two parts then.
