I am currently setting up a block library for our company. I've noticed that the Selector switch child contact does not show the position tags. We would like to be able to show these as we have panels with multiple 2 & 3 position selector switches with parent/child contacts across multiple pages.
I've made a child block with the POS1-3 tags.(attached, jic125 scaled up 1.25) When you assign a parent, it does not fill in the POS1-3 tags. Is there a solution for this?
I also would like to do this for the COLOR tag on other blocks.
Thank you!
If I understand you correctly, you want the state of the contact to be automatically filled in when you insert the symbol? You can do that by adding text to the TEXTVALUE of the partnumber for the contact you are inserting. For instance an AB 800B-PT01 is a 1NC contact block. Enter in the TEXTVALUE field the following STATE=XO to indicate it is closed in the left hand position and open in the right hand position. The problem you will have is when you use the same contact block on a 3 or more position selector switch.
We just enter the position state at the time we place the symbol and fill in the Edit/Insert Component dialog box. See image below.
Scott
Brad Coleman, Electrical Draftsman
I am just in the habit of always entering the state of the contact block when I insert it manually because the desired state is not always the same.
Scott
I brought this up quite a while back and so far, haven't seen any action on it.
The work around I gave is the only one I know of that works. There may be other workarounds, but I haven't come across them.
Regards Brad
