Screencast caused 'The RIbbon does not have any tabs or panels currently loaded'
Cole64
Message 1 of 18
Cole64
I was trying to solve another problem and installed screencast to show my workflow. During install ACADE crashed and when reopened I have 'The RIbbon does not have any tabs or panels currently loaded'. I have tried:
  1. CUILOAD, unloaded ACAD and reloaded ACAD.CUIX  = No fix
  2. CUILOAD, unloaded CHRONICLE, ACAD and juse reloaded ACAD.CUIX  = No fix
  3. Programs and Features/ Autodesk AutoCAD Electrical 2017 - Repair   = No fix
  4. CUILOAD, unloaded acade and reloaded = FIX Smiley Very Happy I then also loaded CHRONICLE with out problems.
Hope this helps anyone else with this problem.
Replies (17)
Message 2 of 18
I will try this in the morning.
I've had enough for today 🙂
Message 3 of 18
TRLitsey
Hi there,
Thanks for this post.  I am missing something?  What was the difference between step 1 and step 4?
Thank you
Please mark as a solution if this works for you, kudos are always welcome
Message 4 of 18
Cole64
Hi TRlitsey,
The difference is that step 1 is just unload and load the ACAD (acade.cuix) and step 4 I load and unload the Electrical (acade.cuix).
Hope this helps.
Colin
Message 5 of 18
I've never done this before.
So I type in CUILOAD?
I just did this and its asking me for the name of customization file to load.
What is the name? It's will be the default name....which is??
Message 6 of 18
When I type in CUILOAD and then acade.cuix I get a message.
Unable to load customization file
acade. cuix
that customization group name already exists.
Message 7 of 18
I switched AutoCAD profiles and I got everything back. But I need to fix ACADE profile.
I tried this:
After loading AutoCAD, the ribbon is blank and shows the message:
The Ribbon does not have any tabs or panels currently loaded.
Solution:To restore the ribbon, try one of the following methods:
  • Switch to a different workspace and then back again.
  • In the Options dialog box, change to a different AutoCAD profile and then back again.
  • Reload the main CUI file:
    • Enter the CUILOAD command.
    • Click the Browse button.
    • Select the ACAD.CUIX file and then click Load.
      • ​If this is already loaded, unload it first and then load it again.
​The problem is I never had a browse button when typing commands.
do you know how to turn that on?
Message 8 of 18
TRLitsey
Hi there,
Hey @rhesusminus, any chance you might have a suggestion with this?  It is a bit outside my sandbox.  Looks like acad.cuix and acade.cuix are installed, who is who?
Thank you
Message 9 of 18
See the Note on this help search I did
Note: The CUIX file is different, depending on the variation of AutoCAD (ex.):
AutoCAD LT = ACADLT.CUIX
AutoCAD Architecture = ACA.CUIX
AutoCAD MEP = MEP.CUIX
AutoCAD Mechanical = ACADM.CUIX
AutoCAD Electrical = ACADE.CUIX
AutoCAD Civil 3D = C3D.CUIX
Message 10 of 18
TRLitsey
He there,
Awesome homework!  Have you gotten up and running?
Message 11 of 18
I'm using a different profile for now. I have to get caught up from being down all day.
I haven't figured it out yet.
My hang up is when I do a command, I don't have a browser. I have to type in the full path and that doesn't work for cuiload command
Message 12 of 18
Message 13 of 18
TRLitsey
Hi again, I am not clear on what you mean.  I think of a 'browser' as the tool to search for files.  Are all of your tools back but the file manager is not working?  Under View > Options, or right clicking in a blank area of the active drawing and selecting Option from the pop-up you can adjust some of the display settings.
Message 14 of 18
Stupid question...how do you browse? where's is the browse button.
Message 15 of 18
TRLitsey
Ummm, still not sure what you mean by 'browse'.  Are we looking for files, commands, web page, or do you mean a general search function?  Is the Menu Bar turned on (command line menubar = 1) for you to open the FILE flyout?
Can you pick one of these if this is what you are 'browsing' for?
Screenshot - 11_4_2016 , 10_39_49 AM.pngScreenshot - 11_4_2016 , 10_38_58 AM.pngScreenshot - 11_4_2016 , 10_37_44 AM.pngScreenshot - 11_4_2016 , 10_35_29 AM.pngScreenshot - 11_4_2016 , 10_34_32 AM.pngScreenshot - 11_4_2016 , 10_33_07 AM.pngScreenshot - 11_4_2016 , 10_31_01 AM.png
Message 16 of 18
rhesusminus
Try typing FILEDIA on the command line, and set it to 1.
This makes AcadE display a dialog box when it expects a filename.
As a side note... I AcadE only asks for a filename on the command line, type the tilde-character (~) and press enter. this should open a dialog box where you can browse for a file.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 17 of 18
THANKS- this is what I needed to know!!
Thanks Again!
Message 18 of 18
That worked!
