Schematics tab missing
Message 1 of 11
I am not able to use schematics as the tab and all references for it are missing.  I have tried resetting to default to no avail.
Replies (10)
Message 2 of 11
J.FOCHT
See if this thread helps you out:
https://forums.autodesk.com/t5/autocad-electrical-forum/schematic-tab-missing-in-autocad-electrical-...
Here is an article that may be helpful too!
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Tabs-or-...
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
Message 3 of 11
TheCADnoob
which work space are you in? WSCURRENT
CADnoob
Message 4 of 11
I checked my workspace and was in 2D Drafting & Annotation.  The ACADE 2D Drafting & Annotation was not available.  I did a reinstall and fixed it.
Message 5 of 11
TRLitsey
Hi there,
You could try to shut down and restart ACE
or
try typing FILETAB on the command line to see if you can turn it on.
Good luck
Please mark as a solution if this works for you, kudos are always welcome
Message 6 of 11
If it happens again I will try this.
Message 7 of 11
Parxx
I have the same trouble on AutoCAD 2022 (version : S.51.0.0) and 2023, I did not success to display the 'Schematic Tab', I tried the following steps for these two AutoCAD versions:
- I installed and unistalled the software on two different computers
- I followed the solution of this link with the Filetab command : https://forums.autodesk.com/t5/autocad-electrical-forum/schematic-tab-missing-in-autocad-electrical-...
- I followed all the advices of this link :  https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Tabs-or-...
- I did a factory reset
Here you have my parameters :
Please could-you help me?
Thanks in advance.
Bests.
Message 8 of 11
rhesusminus
And, you are absolutely 100% sure that you have AutoCAD ELECTRICAL installed, and not just the normal AutoCAD? Your screenshots suggest so.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 9 of 11
Parxx
Yes I just saw that.
I thought that AutoCAD Electrical was in AutoCAD because of this :
Thank you for your answer.
Bests.
Message 10 of 11
rhesusminus
Yup. The keyword is "ACCESS" 🙂
It should be stated clearer that they are separate downloads.
Trond Hasse Lie
Ctrl Alt El
Message 11 of 11
ubaldojohnrafael1
Community Visitor
Community Visitor
same with my electrical autocad 2022. after I undock the ribbon and reset it, the schematic tab and other electrical tabs are missing. seems like it became a normal autocad.
