AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Schematic to Footprint Linking
2 REPLIES 2
586 Views, 2 Replies
I'm having an issue when linking a panel footprint to a schematic symbol.  It doesn't link and the command line has the following information in it.  Has anyone seen this before?  If so how do you fix it?
Command:
reading project database file . . .
Closing mdb file...
Lookup Db:c:\users\jbradtke\documents\acade 2017\aedata\en-us\catalogs\footprint_lookup.mdb Table: AB
No footprint match for AB 800FM-LF3MN3GX10
Error: bad argument value: positive -3
Command:
-Jon
2 REPLIES 2
JeffatPrimex
Using the footprint database editor do you see your part number and a valid block entry for it?
Best regards,
Jeff
in reply to: JeffatPrimex
So I don't know what the actual problem was but I deleted the footprint database and everything is working as expected.  I'll have to dig through the database and figure out why it's breaking the links and not working.
Thank you for your response.
-Jon
