The blocks may be pointing for Horizontal or Vertical blocks, it doesn't matter.
When inserting onto a wire ACADE looks at the line you are inserting the block onto and grabs the correctly orientated block according to the 'V' or 'H' at the beginning of the file name. Be aware that using the checkbox in the component menu will over ride this functionality.
The checkbox will change according to the ladder orientation in the dwg settings. So if the dwg is set to Horizontal ladders, the checkbox will be for vertical ladder insertions and the reverse for Vertical ladders.
The orientation of a block inserted by itself is also affected by this setting. If you have a vertical ladder set, the blocks will come in set to a horizontal orientation suitable for the rungs in a vertical ladder and the reverse for horizontal ladders.
Regards Brad
Brad Coleman, Electrical Draftsman
