Scale all Icons
Scale all Icons
draw86EYC
Scale all Icons
draw86EYC
Good Day
Is it possible to scale all icons/schematic symbols (to 0.8) so i don't have to always change the scale manually.
Often i forget to change the scale when starting and then i will have to do all over again.
james.mcmillanNYR6A
properties > drawing format I think is what you're looking for
draw86EYC
Hi.
That does not work somehow.
The symbols i want to add are still same size.
I know there was a way to scale all symbols in a folder.
james.mcmillanNYR6A
did you change the property on the drawing you are working on? either apply project defaults or apply to that drawing
draw86EYC
Had to restart Autocad but now it works.
Thank you very much!
james.mcmillanNYR6A
No worries. As a footnote, I don't think doing this is a good idea, are you sure your sheet just doesn't need to be bigger?
