AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Run lsp File after AENEXT or AEPREVIOUS Command
3 REPLIES 3
Fisherman120
347 Views, 3 Replies
I am trying to run a simple lsp file to set my text style to "Arial" and the size to "2.5" for the MText. At present the default is "Arial_Bold" and size "4". Is there a way to run a lsp file each time the previous or next drawing is selected.
If not does anybody know where the standard MText defaults can be modified?.
3 REPLIES 3
rhesusminus
in reply to: Fisherman120
The default text style can be set using the TEXTSTYLE system variable.
If the text style isn't set to use a specific height, the TEXTSIZE system variable keeps the default height of the new text.
This should be easy to implement in the acaddoc.lsp so that it's set every time a file is opened.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Fisherman120
in reply to: rhesusminus
Thank you for your response. I tried adding the following to the ACADDOC.lsp which is loaded at startup:
(command "TEXTSTYLE" "Arial")
(command "TEXTSIZE" "2.5")
It did not change the default style and size, any ideas?
rhesusminus
If you do it manually, does it work then?
Trond Hasse Lie
Ctrl Alt El
