Restore AutoCAD Elec
belabas_walid96
Observer Observer
belabas_walid96
Observer
Observer
Hello everyone
I am working on an 2D project and I am kind of Stuck because I don't have access to the "Schematic" and "Electromechanical"  Tool-Tab after resetting the ACADE profile.
How can I restore it?
Ed__Jobe
In the Start menu under the AutoCAD Electrical folder, there is a program Reset Settings To Default. You can also just reset your cui file. In the cui editor, right click on Electrical and select Restore.
Ed
How to post your code.
belabas_walid96
Observer
Observer
Hi
It seems I don't have the ACADE.CIUX (Electrical)
Where can I download its file ?? How can I fix this anyway
rhesusminus
If you haven't made many custom components etc. I'd just reset the entire AutoCAD Electrical to default, as explained in Ed's link.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Ed__Jobe
@belabas_walid96 wrote:
Hi
In your first post, you said you reset the acade profile. Apparently you ended up with acad.cuix instead of acade.cuix. You cad switch cuix's as the main ciux. If you still want to try to only update the cuix, then a clean file can be found in C:\Program Files\Autodesk\AutoCAD 2024\Acade\UserDataCache\en-US\Electrical\UserSupport
However, if you use the restore to default tool I mentioned, it uses the files in UserDataCache to do the restoration. I don't know what other changes you made when you reset the profile, so I recommend using the reset to default tool.
Ed
