In the posted drawing, I have a single relay tied to two contacts. Both contacts show the proper cross-referencing information, but the relay itself doesn't. It acts as if my cross-referencing style isn't properly set up, but everything else works right -- as evidenced by the correctly annotated contacts and the functioning destination arrows on the same drawing.
The issue is in the line referencing. I use the sheet and number style, and for some reason the sheet # isn't coming through, so I get question marks instead.
Does anyone have a clue what's going on here?
you should update project....Project-->Project wide update /retag--> then check both component and cross-reference update
That worked, thanks for the suggestion.
I hadn't tried that simply because I previously had tried updating the component directly and got no result. I didn't think it would matter, doing the update project-wide, since all of the components were on the same drawing.
Thanks again!
Jim
I tried your method. At the page of the relay coil, the cross reference of the contacts show the sheet page of the coil instead of the contact. I have to click on the overwrite function. Please advise any other setting is not done.
