Red lines
Red lines
Arlene_Brown
Red lines
Arlene_Brown
Can someone please advise what the red lines indicate that appear over the wires on a drawing. They disappear as soon as you zoom in or out of a drawing.
Thanks in advance.
TRLitsey
Hi there,
I believe that is a AutoCAD thing.  It is just high lighting what it thinks it is editing.  Next time you see that try using a Regen or Redraw tool to clean the screen.
Good luck
Please mark as a solution if this works for you, kudos are always welcome
rhesusminus
Do you mean the read lines that appear like this, when you run the DWG Audit?
Or is it some other lines you're thinking of? Screenshot?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
