This is the first time I've used the parameter "%A" in both same and between drawing source-destination cross-references.
My same drawing and between drawing format is "%A%D-%N" for this particular customer.
I have selected the "Real time... between drawings" setting in Project Properties, and it is working for the "%D-%N" part of the cross-reference, but I have to go back and update for "%A" to show up.
Is that normal? Can I fix it?
Looks like you had a set up of your styles something like one below. The default setting is %S-%N. I don't think it will retain if you change it to a different one. This has to be logged as an enhancement request in our idea station. I will also raise it with the product team.
https://forums.autodesk.com/t5/autocad-electrical-ideas/idb-p/37
Yes, I have %A%D-%N in "Same Drawing" and "Between Drawings."
Having done two drawing sets now with these settings, I can give more information that I've observed. Component cross-references always pick up the %A just fine. Same drawing source arrows also work. It is mainly source arrows on a different drawing that have to be refreshed - they show up as %D-%N with the %A part missing.
