AutoCAD Electrical Forum
publishing to a .pdf file
1 REPLY 1
snorcisa7FS8E
406 Views, 1 Reply
I'm trying to print out my AE project to a .pdf.
I used the publish command, I selected the sheets in my project to add.
I hit publish, however, when the finished .pdf is created the last sheet is always first , then the rest of the sheets in the correct order. How can I fix this?
Also, it seems like I remember in older versions of AE there was a way to not have it include the layouts, just the model
sheets. Is this still possible?
Thank you all.
1 REPLY 1
Well, I figured it out. You have to select the sheets in reverse order. Select the very last sheet then holding down the shift key select the first sheet. That puts the sheets in the correct order. Seems kinda weird to have to do it like that tho. To not include the layout sheets right click on a file name and uncheck "include layouts when adding sheets".
That gives you only the model sheets.
Technology Administrators
AutoCAD Beta
