Hi all,
I'm trying to publish several dwgs however the page setup I named is not there only 'default' and 'import'. I've done this many times with zero problems but in the past I have noticed this happening. Now it's a mission. Online was zero help.
Please advise
thanks in advance
John
Solved by jseefdrumr. Go to Solution.
Could it be you have been using page setups for model space and now you need page setups for paper space?
You can create page setups for both in the same drawing and save that drawing as page setups.
Best regards,
Jeff
Hi Jim,
I've done all of this. If I 'plot' it comes out perfect but when I 'publish' the page layout that I named is not there, only 'default' and 'import'. I don't know if this matters but there are xrefs attached.
Hi Jeff,
Yes I am aware of this and I have plotted/published many times and it has worked it just seems to be these particular dwgs
Unfortunately I can't, it is the clients property with sensitive info. However, I was able to create a dwg with the setup I needed and it worked. It has to be a setting when it was originally created. Thanks for all of your input!
John
