Project Manager - Main Projects / Sub Projects
I am currently creating multiple projects for an end user, which are ultimately going to the same location. Each project has it's own billing code that we use within our projects. Is there a way to have SubProjects within a Main Project Folder structure? Basically, the Main Project, would only have to update the current sheet number and sheet number max as other sub projects are added,  I still want the Sub Projects have control over the DWG Name, as each project has a different name. This way, any S/D between projects can be correctly linked between projects without having a "Dead" S/D that is manually manipulated.
Hopefully I explained well enough for someone to follow along. I have an example below of what would be basically in each folder structure below.
Example:
ProjectManager-
MainProject.wdp
MainProject.wdt
MainProject.apex
  • SubProject1
    • SubProject1.wdp
    • SubProject1.wdt
    • SubProject1.apex
    • SubProject1.dwg
    • etc.
  • SubProject2
    • SubProject2.wdp
    • SubProject2.wdt
    • SubProject2.dwg
    • SubProject2.apex
    • etc.
  • SubProject3
    • SubProject3.wdp
    • SubProject3.wdt
    • SubProject3.dwg
    • SubProject3.apex
    • etc.
Joel
jseefdrumr
Check out Doug McAlexander's Super Project Manager: http://www.ecadconsultant.com/tips.html
First video in the list. Plus, there's lots of other good info on that page.
Jim
Jim Seefeldt
Electrical Engineering Technician
jseefdrumr,
Thanks for your quick response, although the link you provided, does help in a way. I do not have the "Super Project Manager" add-on. I have found a blog online, although it's from 2009,  that explains how to do a Master / Sub Projects within AutoCAD. Once you understand the folder layout and how to allocate the drawings, it is a pretty simple task at hand to create.
https://nateholt.wordpress.com/2009/08/12/multiple-projects-within-a-super-project-autocad-electrica...
