AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Possible Bom Bug? Or User Error
8 REPLIES 8
Message 1 of 9
461 Views, 8 Replies
Example Drawing Attached. - Using AutoCAD Electrical 2016
2 identical MCCBS ( HND400H) , the only difference is that one contains a Sub assembly.
Running a BOM Report,
Normal Tallied Format correctly reports 2 x HND400H
Tallied Purchase Format ( The one i really need ) only reports 1 x HND400H
Am i going crazy and missing something simple or is this a legitimate bug?
8 REPLIES 8
Message 2 of 9
yuvaraj_jaganathan
Hi Stuart,
Thank you for reporting this issue.
I could see that you are using the Assembly code for one of the 'HND400H' (located in the left side of the drawing) as '400A SPD'.
Are you using the the Assembly code to define the sub-assemblies as well?
Yuvaraj J
Yuvaraj Jaganathan
Senior QA Analyst
www.autodesk.com
Message 3 of 9
in reply to: yuvaraj_jaganathan
yes, I believe they are correctly defined
Message 4 of 9
yuvaraj_jaganathan
Hi Stuart,
We have logged this issue  in our tracking system.
As a workaround, you can create an additional copy of the catalog for the assembly as below and generate the report.
Yuvaraj Jaganathan
Senior QA Analyst
www.autodesk.com
Message 5 of 9
Thanks for your help.... Hope it gets solved soon
Message 6 of 9
Any sign of a fix for this issue yet?
Message 7 of 9
Double post...... 😞
Message 8 of 9
yuvaraj_jaganathan
Hi Stuart,
This issue is already logged in our tracking system.
Could you able to solve the issue with the workaround posted in the previous reply?
Yuvaraj J
Yuvaraj Jaganathan
Senior QA Analyst
www.autodesk.com
Message 9 of 9
While the workaround does work it is not ideal, we have many assemblies affected by this bug. The workaround then needs a manual update to the BOM before we upload to our SAP system.
It is very dissapointing that the core functionality of your product does not work as advertised and we have to resort to manual updates and workarounds.
Please can provide an esitmate on when functionality will be restored.
