Is there a way to add Catalog number to the Multiple Catalog for a PLC IO Card in the PLC IO Utility Spreadsheet?
So I solved it.
For those who may be interested:
- First I opened all the blockes with "Module Info" in the name used to build the Parametrick PLCs and added MFG01 to MFG05 and CAT01 to CAT05 attributes to these.
(One can see what the different block names is under "Settings" ine the "PLC Database File Editor")
-Then I reused the "G3" in the PLC Excel-sheet and added the Part and Manufactirer for the Multiple BOM as: ";MFG01=partmfg;CAT01=partno"
- I changed the "Group numbers" to use col 5 from my Spread sheet
-The result equals success:
Part and Manufacurer fed to the Multiple BOM via the "PLC I/O utility"
