Message 1 of 1
PLC I/O Utility Erasing Section and Drawing Value From Existing DWG?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to run the PLC I/O Utility but for whatever reason AutoCAD is erasing the section and drawing values when it opens the drawings to place the I/O on.
The reason this is an issue is because our tag format is %A%D%N%X%F which is causing most of the PLC blocks to have the same tags since we do not have the sheet value as part of the tag name… All of the drawings are made with the attributes for drawing and section filled out but this did not prevent the issue.
Any idea if there is a way to use the PLC I/O utility without the drawing and section attributes being erased from drawings?
