PLC Component Report with Connectors
nathan.averett
nathan.averett
I have drawn a set of schematics that are showing an m12 cable connected to an IP67 I/O block. I have used the child PLC block to represent the IO point. I have included the M12 connectors on the cable because we typically use field wireable connectors and I want to show them so they are included on the BOM. When I run a PLC component report I get the PJ connector component in the report and not the photo-eye the I want to see in the report. Is there any way to make this ignore the PJ and CBL markers in the report? Is there a better way to show this IO point connection?
PLC Point SchematicPLC Point Schematic
PLC ReportPLC Report
rhesusminus
There's no way to make AcadE read "through" the connector.
Can you put the part number for the connectors as a multi-cat on the cable symbols, and draw some "dummy" connectors in the schematics?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
nathan.averett
Yea, that's what I thought I would need to do. Thanks for clarifying that ACADE doesn't support this.
