PLC Builder "Break After" issue
gcsjlewis
gcsjlewis
When splitting a PLC into multiple pieces (using the break after check box in the database file editor), the tag attribute is lower than it should be.  It actually runs into the break line that ACADE generates.  Is there a block that I can modify to slide that TAG attribute up?  I have attached a screen shot for clarity.
We use a horizontal 8-graphic style setup.  The answer may be to go through all the individual HP8.... CAD files and where ever I come across the TAG attribute, just slide it up .25".  I just wasn't sure if there is an easier way.
rhesusminus
No easier way unfortunately.
The blocks are used to build the PLC modules on the fly.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
gcsjlewis
I thought as much, but I wasn't sure if there was a "hidden" block somewhere that ACADE uses for that particular attribute after a break.  Ultimately its 30 mins tops to fix.
Thanks!
