AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Pin list
6 REPLIES 6
1122 Views, 6 Replies
Pin list
Hi guys, I have a question.
Before I determine and wrote pins I have cross-ref contacts like this:
After I wrote pins the contacts swap on:
When there is more pins the program make group of NC and after them goes NO contacts. What I need to do to make that location (numbers on the right) be more important then the type of pins?
I am using AutoCAD Electrical 2016.
6 REPLIES 6
rhesusminus
Did you add a pinlist to your component/catalog database?
Are these change-over contacts?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
I didn`t make any database. Regular relay contact.
rhesusminus
Can you share the drawing, so we can have a look at it?
Trond Hasse Lie
Ctrl Alt El
There is a whole project:
https://mega.nz/file/LpsSmKwZ#9SZBa0NHcp6GG899XoHJjm9crnr2R-RgrUWKxclIMZE
It is a reconstruction of an old machine, from 80-es, and I drawn a schema like the original with few changes.
You asked me in the previous post is there a change over contact - I don`t drawn them like that, but physically they are relay with SPDT contact. I must drawn them as a regular SPST NO and SPST NC contact, because in ACADE SPDT NC contact is always on the left side. And  in my shema I, sometimes, need NC contact on the right. Thats why I drawn two SPST contact one beside other (page 7, for example). But their pins are 8-5 and 8-1, not 1-2 and 3-4 like in SPSD.
ACADE symbol
rhesusminus
Adding a pin list to the parent component (coil), will fix this.
The format is:
3 comma "Common Pin" comma "NO pin" comma "NC pin".
Then separate the contacts by semicolon:
Trond Hasse Lie
Ctrl Alt El
Thanks a lot! I get it 😊
