Panel Layout with extra connections?
rmarchioniZN2N4
rmarchioniZN2N4
i have just started using ACADE and i created some new footprint and was assembling a panel and began noticing all these "x" on my components.  they are not in the symbols that i created and i have no idea were they are coming from.  can someone help?
OP21
Check if you are displaying your point style.
Type: PTYPE
Maybe you have something on by default?
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
rmarchioniZN2N4
Thank you, that was it.
OP21
Glad to help...
->"P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you."<-
Hope this helps!
Omar
