07:08 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Folks.
What's the best way to get componnents into a panel layout that aren't necessarily seen on the drawing, but you will want it to show up on a report?
For example a 3-pole fuse holder with 3 fuses inside. You can't see the fuses, you only need to capture the fuse block on the layout, however I want the fuses with their part numbers to show up on the report. Thank you!
Link copied
