AutoCAD Electrical Forum
Overload contact symbol crowded - ACADE'09
1 REPLY 1
813 Views, 1 Reply
I have been trying to find some standard that says that an overload n.c. contact MUST be on the L2 side of a contactor coil, but I am getting conflicting answers and examples. It is typically placed on the L2 side, but I have found examples of it on L1 side as well. I cannot find anything telling me why it should be placed on any particular side.
My reason for bringing this up is because the contactor coil symbol provided by ACADE does not allow enough room to the right of the symbol to place the contact in the wire. The coil's attributes are in the way, but I don't want to revise the block because some of our smaller motor units do not use an overload.
Does anyone know of any standard that specifies the location of the overload contact, or does it matter which side of the coil it is on?
If the overload contact must be on the L2 side of the coil, shouldn't the motor contactor coil symbols attributes be placed farther away from the symbol so that it can be inserted in the correct place without having to move them after insertion?
1 REPLY 1
I would say it all depends on where you want the
actual overload connected, as well as the wiring regulations in your
country.
The general standard here in Australia is for the
overload to be on the load side of the contactor/switch. I have yet to see a
panel with the overload before the contactor.
Same with protection CT's. I've seen
protection CT's on the line side of a circuit breaker but that was an incomer
for a HV switchboard and the feeders had the CT's after the
breaker.
Regards Brad
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
should be placed on any particular side. My reason for bringing this up is
of our smaller motor units do not use an overload. Does anyone know of any
matter which side of the coil it is on? If the overload contact must be on the
Technology Administrators
AutoCAD Beta
